Yeah that I'm not sure of. I don't know if it's the Parasound amp that is causing it or the receiver or something else.
A great way to find out if the amplifier is the source is to connect a pair of audio cables to the input and plug the free ends together- this shorts the pins to the sleeves and is the worst case-scenario for noise. It's easier to do with cheap cables because the metal isn't as stiff. If you have a cheap cable and would be OK with sacrificing it, you can cut it at some point, strip the center wire and twist it together with the shield wires. If you would use it repeatedly in the future, you could make it very short and solder the wires to make it more permanent as a test tool.
Do you have dimmers on your lights, lamp modules or anything that's not just a toggling light switch? My guitars buzz and it's caused by a Lutron Caseta lamp module- the buzz is gone when the dimmer is turned off.
If you have ear buds or headphones, it's easier to find sources of noise between source devices and AVR.
You might try connecting a wire between the ground screw next to the 12V output on the Parasound and the signal ground on the Denon. You can also connect a wire from the screw to the shield of one audio cable (either piece, try it on the Denon first)- sounds weird, but it can work. I have had good success with this one in car and home/pro audio situations.
