Hi, everyone, I'm fairly new here but I've been lurking for the past 1.5-2 years--it's a nice escape while I'm at work.
To the point: I'm considering investing in a pair of Sennheiser HD650s. From all the research I've done, I think I'd like them. I've also gathered that these babies need to be driven properly with an amplifier. Is this completely true? Partially?
I've been looking at a portable solution, given the above information. After more extensive research, I've sort of narrowed it down based on this criteria:
- Can sufficiently/comfortably drive the Sennheiser HD650s
- Can run off of a replaceable battery--most likely a 9V
- Highest quality opamps and other components for a reasonable price--will spend more if justifiable
The few I've looked at are a custom Mini³ built by MisterX, a Meier Audio CORDA Headsix (Head-Fi special), CORDA XXS, and a Headstage Lyrix Pro total.
Has anyone used any of them? Are the XXS and Headsix essentially identical? Do I need an amp? I've read about cMoys but they sound junky. I'm looking to keep the amp under $200 and I don't think I'd care for features like crossfeed filter, etc. even if they are included in some of the ones I've listed.
My sources will most likely be an iPod for portable use (not in the public though--wouldn't want the HD650s to get damaged or nicked) and my computer for home listening.
Now I've also been considering a few other things. If I invest in a decent receiver (with a new Pioneer 9G purchase later this year
), would I even need a dedicated headphone amp? Don't most receivers have poor analog out components for headphones?
I've also looked at just upgrading my computer's sound card. I've been looking at a HT Omega Claro+ which has AD8610 opamps and a front panel connector. How well would that work just for a home listening solution and scrapping the portable one?
Thoughts?
