Popcorn Hour vs iStar vs TVIX HD-m6500A
G
giyad
I am in the process of setting up my home theater. I currently have a TV, and I have a Receiver in mind as well.
I have: Samsung LN-46A750
Want to get: Yamaha RX-V663
I'm going to connect my TV to receiver via HDMI. Then I want to hook up my content (ripped movies, music, photos, etc..) to my TV. I was thinking about an HTPC, but that route seems to be expensive and probably not worth the effort.
So, I'm thinking now about getting either:
1) Popcorn Hour with a PVR (most likely the Hauppage, or possibly GB-PVR)
2) iStar mini with a PVR as well, same set up as above most likely.
3) TVIX HD-M6500A with a TV Tuner to record and pause cable.
Now they all have their pros and cons, so I want you guys to help me decide if you can.
Here are some of the pros/cons I found per device.
Popcorn Hour
Pros: Its got internal storage (sold separately). Plays all formats, and HD content. Small, small carbon footprint. Good forums and updates are frequent.
Cons: Internal storage is IDE and there is no SATA... There is also no way to record and pause unless getting an external PVR. The main thing though is I hear the UI is crap, and if your putting an internal hard drive some people have had heat issues.
iStar
Pros: Plays all formats, and HD. Tiniest of the devices. Takes eSATA devices for external storage.
Cons: Storage is external. No PVR.
TVIX M6500A
Pros: Plays all formats, and HD. Nice LCD. Good remote. Takes eSATA. Can buy a TV Tuner to record and pause. Good UI!!
Cons: External storage.
What do you guys think?
jamie2112
Tvix would be my pick of the litter of those 3 you listed.
jamie2112
I also think Apple TV is another route to go if you have a Mac.
mirkanos
Hdmi 1.3
Hi!
I think u are forgetting one thing, ISTAR have HDMI 1.3 ans Popcorn HDMI 1.1.
I dont know if this question is important. Anybody knows?
mirkanos
Apple TV??!?
Apple TV????????'
xDDDDDDDDDDDDDDDD
Please...
G
giyad
Hi!
1.3 supports HD audio formats while 1.1 does not. I don't think it makes a big difference though...
W
waldenlima
Tvix is good, this is the first choice for you. but a little expensive.
Another choice you can check LimHD 360s or 310s from Tomacro,
Looks also nice, but cheap, you can google it.
W
waldenlima
looks this thread also have been released in AVS, right?
G
giyad
haha, yeah sorry i posted it on a couple of forums, AVS had the most particpation
