The Denon AVR-3805 has a hard time
driving any speaker below 8 ohms.
I don't know if I agree with that statement. There's a lot of speakers rated at 6 ohms with high spl ratings that do well with lesser receivers. I've heard the 3805 drive a set of Magnapans without a hitch. The specs on both units are somewhat comparable. I'm not sure why Denon chose to rate the 3805 at 1 kHz into 6 ohms, but if they used the entire bandwidth (20-20kHz) in their rating, I'm confident it would be at least 140 watts per channel based on it's rating into 8 ohms at full bandwidth.
The LSi's are some impressive speakers, but as said before, you definitely pay for the smoother midrange and highs. The same could be said when comparing a set of Magnapans to the LSi's, but then you are talking another sizable price difference.
Denon AVR3805
7 Channels equal power amplifier section • 120 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 160 watts per channel (6 ohms, 1 kHz, <.7%THD)
Dynamic power 210x2 at 4 ohms
Denon AVR4802
7 Channels equal power amplifier section • 125 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 150 watts per channel (6 ohms, 20 Hz-20 kHz, <.05%THD)
Dynamic power 270x2 at 4 ohms
