Polk Subwoofer for Free!!!
rpls5724
I noticed at Tweeters Store & Ceutchfield website the are offering a free
PSW10 subwoffer valued at $200 with the purchase of a $499+ HT system. my questions are:
1 Is a Polk HT system worth the money
2 Is this Sub worth a dam they also give you the option to use the $200 offer as credit to upgrade yes or no?
3 Should I move on and keep looking at othe speakers.
THX
F
fireshoes
Well pretty much any "subwoofer" for $200 retail isn't really worth a damn. However if your budget is pretty tight, it would get some thump in your system until your next upgrade. :)
sjdgpt
Received the same sub with my Polk LSi's.
Bass output is OK, not great, but at the same time it is clean and acceptable for HT in a small room.
