Polk or Pro Solutions In-Ceiling Speakers?
G
gwatkins
Hello,
I am setting up a new home theatre and home audio system.
For the home theatre system, I am going with a Panasonic 50” 1080P plasma.
To go with this, I am using a Martin Logan sound system - 2 front speaker Vistas, 2 Tickets for in-ceiling rear, a Cinema for the center speaker, and a Depth Subwoofer.
I am using a NuVo home audio system to take the sound to other parts of the house – upstairs and downstairs.
I am looking to use in-ceiling stereo speakers (less expensive than the Martin Logans) for other parts of the house.
I have had two brands recommended by my local AV supplier. Would you recommend Polk or Pro Solutions for this?
I have been waiting a long time to put this system together, and any input is appreciated!
Thanks!!
dorokusai
dorokusai
There are a number of brands that most folks never hear about in the custome install world. ProSolutions would be one of them. I'm sure if it was a recommendation from your loacl AV rep, it was for a reason.
If you ensure that the application is covered by either model line, you probably can't go wrong. I would lean towards Polk but that's a given.
Good luck and perhaps someone with direct experience with that brand can offer a comparison.
Mark
Polk Audio CS
