demonsof
Hi,
I have recently ought a new Pioneer VSX 515 receiver, it was all working fine till today i hooked up my roof antenna to my tv, now i hear a buzzing noise, but it only happens when i have the amp set to my computer asing headphone jack from computer to RCA into CD input on the amp, with it all plugged in i hear the buzzing noise while its on CD but when i unplugged the antenna i figured something was teribly wrong and the noise aint a like a pretty little birdie whistling....please help i need MUSIC!!!!!!!!!lol:mad:
demonsof
By the way i have my computer>CD Input TV>TV/SAT input DVD>DVD/VCR input all work fine apart from the computer and i have tried runing the computer through different inputs.
jaxvon
jaxvon
Many times computer headphone jacks are very noisy. If I connect my laptop to anything but headphones I get the same terrible effect. I would suggest you pick up something that transmits a digital signal to your receiver. That will eliminate the noise issue. This is something I plan on getting when I have the budget available for HT stuff again (too much going into school ATM):
http://www.impactacoustics.com/product.asp?cat_id=1007&sku=22327
THen just pick up a TOSLINK cable and you're good to go.
Spiffyfast
Spiffyfast
any computer sound card with a digital out will work, I go with an internal card, they usually, I said usually, have cleaner sound than a usb sound card
demonsof
so your saying i should get an optical cable to go into my 6.1 sound card then into my receiver?
