Please suggest a good receiver for this system. Thankyou.
GranteedEV
GranteedEV
Let's see:
Image B6 Mains - 89dB sensitivity / 6 ohms nominal impedance w 4 Ohm dips / 150 Watts RMS power handling
Image C5 Center - 88dB sensitivity / 6 ohms nominal impedance w 4 Ohm dips / 150 Watts RMS power handling
Image B4 Surrounds - 85dB sensitivity / 6 ohms nominal impedance w 4 Ohm dips / 60 Watts RMS power handling
So what you want is a robust, stable power amp section; the fronts are fairly sensitive and the rears aren't going to be drawing too much current unless you're listening to 5ch music.
Any decent 7-channel receiver rated at 80+wpc into stereo will be more than sufficient
But if you really wanna go all out without breaking the bank, an Emotiva UPA-5 for example would be more than sufficient for this at its current sale price of 400 dollars, if you're interested in having a separate amp and processor. That's probably ~140wpc into 6 ohms into all 5 channels.
More importantly - what do you want out of your receiver - usability, auto-calibration etc. That's where most differences are.
seymoria
Thank you for the help.
Both auto calibration and useability would be desirable.
I will not be upgrading in near future.
Do you also have any Marantz or Denon suggestions?
Thanks.
dapack69
dapack69
I really don't think you could go wrong with either company since Marantz is now owned by Denon. I keep hearing that Marantz has a warm sound it, so if you listen to more music then HT, you might consider that one ahead of the Denon or visa versa.
tsand
I have had some great luck with Emotiva products. You might give them a look. They are close to Outlaw in that they are internet only and have pretty good value for the money.
seymoria
Power Requirements Summary (for your recommendation)
Subwoofer (01 EA)
Amplifier Power :
Continuous 150 Watts
Dynamic 225 Watts
Dynamic Peak 450Watts
Bookshelf/Surrounds (04 EA)
Input Power
RMS, Clipping < 10% of the Time
Recommended 20 - 150 Watts
Program 150 Watts
Impedence
Nominal 6 Ohms
Minimum 4 Ohms
Center (01)
Input Power
Program 150 Watts
Impedence
Nominal 6 Ohms
Minimum 4 Ohms
Thank you for your recommendations.
seymoria
Hi.
I think Marantz SR5004 would be nice.
Thank you all for your suggestions.
L
lowc
I 2nd the Emotiva suggestion, great performance for the money.
