please some1 help me i cant stand not knowing lol
dustywadham
please help me
ok here gose i have had an onkyo 606 which has
ps3 vair hdmi
sky hd vair hdmi and optercal
7.1 moraunt shout 901i speakers and sub
all going to a sony kdl-40w/4500
all has been working fine for 12 months the day my warrnety runs out i play the ps3 which is the new slimline and now the it cuts out the imeg and sound tv filkers as if it is try to get a segnal then comes back on if any1 has had the same problem or has worked out y it dose this pls help
many thanks
ps please excuss spelling as i am pants at it lol
markw
This ain't twitter, dude. I have no fargin' idea what you're trying to say.
We're pretty lax as far as spelling goes, but you have to do a little better than that.
If you expect people to take the time to try to read your post, understand your problem, and compose a comprehensible reply, the least you could do is write it so others can understand you.
dustywadham
please help me
system set up
onkyo tr-sx 606
ps3 slimline
sky hd
sony kdl-40w-4500
all are linked to the av through hdmi cables
ok i will try again as my other post did not make the grade as markw so kindly pointed out.
i was playing my ps3 recently and the signal went to the tv the screen. the screen went black and the souce input comes up saying no input.
2 secs later pic comes back and sound i think this has some thing to do with the onk as i used to have the ps3 hard wierd direct to the tv and no problems. i am using hdmi port number 4 which is for game/tv tried new cable and different hdmi port still same problem.
dose anyone have any idea y this is or how i can sort this.
hope this is up to your standards markw and u understand now
hope this dose make more sence now
markw
The game works fine when connected via HDMI directly to the TV set.
The problem only arises when you connect the game via HDMI to the oinker, and then from the oinker to the TV via HDMI.
You changed the HDMI ports on the TV set (good move) but the problem remained.
You then replaced the HDMI cable between the oinker and the TV. Another good move.
Since the problem remained, this leaves only the receiver as the source of your issues.
I've read about there being "handshake" issues when using some units with some receivers. Not being intimately familiar with either the receiver of the game, I'm outta ideas.
Perhaps if you state the model number of the receiver, someone else can take over from here.
Seriously, what is your native language?
dustywadham
the model of the onkyo is tx-sr606 i did stat this in my last post
my frist langeg is english but i do have a big problem with it but never mind.
Your problem is that your receiver does not have the repeater HDCP codes, to keep verifying you are not an AV pirate. This is a classic HDMI repeater architecture problem, or rather lack thereof.
Pancakes™
ive had similar problems myself.. except: i dont have a fancy receiver. just the red&white to the back of the receiver coming from the ps3 and the hdmi in a benq g2400w 24" LCD. what would happen is i would get sound of the ps3 loading etc, but the lcd would go blue, flicker in two different shades of black, and then tell me that no input is selected. so i instantly thought, oh crap, byebye ps3?? i done some quick googling and it said to hold the power button for like 8 seconds which forces the system to shutdown + a reset.. i done that a few times and all was good. so im guessing its something to do with the ps3 or even possibly the HDMI Cable..
try this and i hope it helps!!
MatthewB.
I have an Onkyo 805 and I have this problem with my Oppo DVD player, it's the HDMI port thats the problem. Slot 2 and 3 work great, but slot 1 I have to unplug and plug back in to get it to accept the signal. I finally just gave up on that one HDMI port and use optical and Component. Check the other HDMI slots and see if that fixes your problem.
dustywadham
ok if this is the case what can i do or do i need to buy a new resiver if so can any1 tell me what is the same as mine with this option.
as for checking the ports it dose it on all ports and it is booked in to be repaired on monday. they thought it was the settings when they talked me though setting it up proply and it is still happening.
Your receiver has the correct HDCP codes. I have downloaded your manual. Make sure you have followed the instructions on page 43 of your manual.
Make sure that HDMI port is assigned to the input you are using and that the HDMI port you are using is not assigned to more than one input.
If it is not working with correct set up, then the HDMI board has failed and your unit needs repair.
Have you tried to see if another device that outputs HDMI can output to your TV via your receiver?
dustywadham
I have checked what u said and got talked though by jenson who do the repairs for onkyo he said all was set up right but after the last feed I did as u said and rechecked all ok so I guess it is the unit I would like to give a big thanks to all who have helped. I will be sending it back next week and hope all will work. If not I will give up and buy a new unit any1 know what I should get next
