Hi Everyone!
I'll try to keep this simple and to the point. I want to install a multi-room audio system that allows bluetooth streaming from my iphone, and surround sound for movies/tv, that uses in-wall speakers. I'm trying to see what my best options are with the equipment I have. I am not opposed to buying/selling components needed - I could just really benefit from anyone who knows that they're doing, as I do not.
ORIGINAL PLAN:
Living Room Area - Marantz NR 1605 with a 5.1 setup and the extra zone being used in the back yard.
Master Bedroom - Marantz NR 1603 w/ RX101 with a 5.1 setup and extra zone being used in the master bathroom.
I have the two amplifiers mentioned above and I was starting to research speakers. The planned install would have been fairly simple as I was just going to run the speaker wire behind the baseboard in both rooms. The way it's laid out and the transitions would allow for it to be (at least what appears) quick and painless.
THE WRENCH IN MY PLAN:
I was on eBay one night and made an impulse buy... which I "hope" was a good deal.
I now have complete, gently used, Bose BuiltInvisible Lifestyle system consisting of the following:
Bose Lifestyle AV38 DVD Unit w/ Remote (1)
Bose VS-2 Video Enhancer (1)
Bose Theater Amp - TA-2 (1)
Bose Amp - SA-2 (1)
Bose Lifestyle Roommate w/ Remote (1)
Bose AdaptIQ Small Cube In-Wall Speakers (3)
Bose Virtually Invisible 191 Speakers (6)
Bose BuiltInvisible in-floor/ceiling Acoustimass sub (1)
Huge box full of Adaptiq CDs, Bose link cables, speaker wire, lots of wall-plates, bose link plates, multi pin plates and adapters.
I'd like to know what you any of you would do with what's listed above to get the best results/sound and that accomplishes the multi-zones mentioned and the bluetooth/wireless streaming. I'm open to any and all suggestions, as I mentioned, I just don't know enough about what I have or what I'm doing. I've read some, and have some general questions/thoughts.
USING MARANTZ AMP IN LIVING ROOM:
1) Using the Marantz Amp in the living room with the Bose speakers seems to be an easy solution. I believe the only additional thing I'd need to learn would be the best way to power the passive hidden acoustimass subwoofer. So I'd need an additional amp for that.
2) I read the AdaptIQ speakers can ONLY be used with a Lifestyle system without damaging them. Something about the crossovers? If that's true, then I'm down three speakers by not using that system. I'd like to think that the Marantz amp would be advanced enough to have those settings to use them safely though?
3) The Lifestyle Roommate can only be used with the Lifestyle System/Bose Link.
LIFESTYLE SYSTEM IN LIVING ROOM:
1) Is the AV38 a decent, I don't know what the correct term is - but, "sound processor" compared with the Marantz NR series?
2)In the future I could add sound to the entire house. It seems that the Lifestyle system supports up to 14 zones? If it's easy to use, it would be cool to have sound in the other bedrooms, home office, etc.
3) A Bose adapter seems to be available to let the lifestyle system stream bluetooth?? Or maybe an aftermarket version would work better?
4) It will definitely be a more complex installation.
Regardless of which main unit used - what speakers should I use where? What makes sense?
Thanks so much! Really looking forward to the responses/advice!
