I have hooked up Presence Speakers to my Yamaha RX-V2400, (making it 7.1), and have turned them on in the software, in all the places that I should, I think, however I am experiencing a slight problem.
Even though I have turned off the Zone 2 amp, the Zone 2 and 3 lights remain on in the Yammies display and the display does not show the two little presence lines, (indicating they are connected and on), above the "FL C FR" symbols.
Yes I am using Cinema DSP to check the sound, (several different ones, like DD enhanced, Adventure, Sci-Fi and Spectacle), and nadda.
Now if I do a test sound, they are included in the test and yes I have 7 speakers selected and Presence-Yes/SB-No.
Any ideas???
Also, with this setup, is it possible to play DPLIIx or is that just for 7.1 with Surround Back?
