New to the forum, Hi all.
Alright. My record player's belt drive gear, the gear on which the belt rides and turns the table itself, was squeaking heavily.
I went and bought a pen sized bottle of liquid WD-40 to fix this probem.
I put some drops on the top of the gear, hoping gravity would coat the inside of the gear.
Ever since I did this, the traction of the belt on the gear sucks, and records play at a slower RPM.
Any suggestions regarding how I could fix this?
I already used a Q-tip with water to try and 'wash' the gear of any WD-40 in an attempt to allow more traction.
I also took the belt out and put it under some water and let it dry to see if the belt was the problem.
I could tell that after doing these quick fixits there is more traction, but not a normal amount of traction, and records still play at a reduced RPM.
