Try in the following order,
1) Check cables, power and signal (if this does not work go to point 3)
2) Calibrate (this will tell you if the sub is underpowered for your needs)
3) Exchange for new one
3b) Calibrate (realize that you dont like the sub after all... just kidding
4) Return, use the funds for a much better sub from different manufacturer
