Thanks for reading, and replying. Yes, I got the PSB Syncrony Ones -- they should be here next week.
What's the GLS and the Unique locking plugs?
They are just terminations. FWIW, nothing beats bare speaker wire. The convenience with having the spade/banana as you put it is no worry of corrosion over time (but you can snip new wire once/twice a year, and even that's prolly overkill).
The "locking" bananas have a termination that has a sheath of sorts that goes over it. All that happens is you twist the "sheath", and the plug will simply stay put; won't come loose. (The inner part expands.)
We are talking small fries here. As with your other thread, you are too worried about whether your salt is kosher or not, how well the grinder works, and not how prime the steak is, or the grille, temperature, etc. Actually, that's probably unfair; processor and amp will have much more impact than choice of wire.
wire is wire is wire, as long as it's not a POS
construction. And no, money has almost nothing to do with it. Google the 50 HDMI cable shootout at AH for instance. $15 HDMI cables are outperforming $400 cables. It's all a sham, outside of having a reputable honest company. Yeah, I know, what the hell is that . . .
