I have spots for 10 speakers (5 zones with 2 speakers in each) and I am replacing them with new ones. I'm not sure what yet, but I have been looking at these:
Polk Audio RC80i 2-Way In-Ceiling Speakers
These are 8 ohm speakers rated for:
50 watts peak power handling
130 watts RMS
For an amplifier...
Do I need something like this, which is 65 watts RMS per channel:
DMA-1275 High Efficiency Mulit-Channel Amplifier[/url]
Or something less powerful like this (40 watts RMS per channel):
DMA-1240 High Efficiency Multi-Channel Amplifier
OR should I go with a couple stereo amplifiers instead of the 12 channel one and use a speaker selector.
I'm just trying to figure out a gauge for how much power I will need when shopping for speakers.
I'm pretty confused as to what numbers to look at and if I need to match the power or if being under is sufficient (and if so, how under is sufficient).
If anyone could bluntly explain this to me it would be appreciated.
SNELL OH-T7 Full-range 6.5-inch coax “Direct Power†waveguide Each | Accessories4less these are a steal. not sure what size holes you have rite now...
As far as how much power- I run 6 zones of 2 off of a upa200 which is 250watts total and it never even gets a workout, honestly I would be surrised if we use half of its power, but we mostly use it for ambiance background music or when my wife is cleaning......
To figure out how much power you need, first pick a speaker, then look up the sens rating, and then choose your listening level, and you listening distance, then plug it all in the calculator...
Amplifier Power Required Calculator
So if you use them Snell speakers which have a 1w @1m sens of 88db, and want to listen at 85db 12 feet away {call it 4m}, you need about 16watts {with 3db of headroom}... I like to double them figure or go for 6db headroom...
I would take the largest room and use the measurements from it...
Now as far as multi channel amps, there are some guys that like them , but I had some bad luck with them and since I went to a monoprice selector box and emotiva 2 channel amp I havent had one problem, smooth as silk...
The dayton apa150 amps are also a good lower price choice, but for your system I would go with the UPA500 and 2 selector boxes, this will give you 80w per channel {with an extra channel for a mono sub maybe
} Or if you want more power a pair of upa200's... Just make sure what ever you get is 4 ohm stable....
