PLEASE HELP! 450 Watt Cont speaker VS 400W Amp, WILL IT BLOW?
jcjc1980
I'm a DJ at a club and don't know too much about audio, just some basics.
I've been running two 300 Watt Program/ 600 Watt Peak Power Yamaha BR 12's AND one JBL TR225 (450W Cont, 1800 pink peak, whatever PINK means)
Since my Amp is a powered mixer (Yamaha EMX68S, 400/channel @ 4 ohms) will it blow my JBL? I know my Yamaha's are ok, but I'm scared I'm gonna underpower my JBL no matter what configuration it is set to, and I DEFINITELY can't go 8 ohm (800W) because the speaker is a 4 ohm spk.
PLEASE HELP!
ALSO - looking for advice on a powered subwoofer under 600.00 or some way of hooking up a passive sub to my powered mixer without sucking the life out of the amp or underpowering anything.
THANK YOU!!:D
Your speakers have a MAX rating. You don't NEED 400w to drive them.
You don't have a choice on the impedence if the speaker is 4 Ohms nominal (and is not configurable via wiring), meaning if it is 4 Ohms, it doesn't matter what your configuration at the amp is, it will see 4 Ohms. Something else doesn't sound right there - the output should go UP when the impedance is lowered, not drop.
Pink means tested with Pink noise, not across the full band.
jcjc1980
My amp says 400W+400W/4ohms
270W+270W/8ohms
800W/8ohms bridge
My Speaker (JBL) says
• Nominal Impedance: 4 ohm
• Power Capacity: Continuous Pink Noise: 450W
Peak Pink Noise: 1800W
The guy (kind of a jerk) at JBL said get a bigger amp, but I've been running it on 1 CHANNEL daisy chained to one of the yamaha's (300/600pk) for about 3 months now and had no problems. As far as the 4ohm/8ohm, I guess the amp reads by itself from the resistance it receive? Is that right?
The question is whether that amp can run bridged into 4 Ohms, and my guess is it probably won't like it. That might be why he said that, and you are correct in that in bridged mode, the output is higher though the impedance internally seen by the amp is already lowered by running it that way. In other words, in bridged mode, you are limited to 8 Ohms. The way the amp delivers power is affected by the impedance of the speaker; lower impedance will draw more current from the amp, making it work harder. In bridged mode, you cut that in half because the two channels are tied together into one, so the amp is already working harder.
It is hard to say if you will damage the driver; it really depends on how loud you have it cranked, and whether or not you are playing it to the point of clipping. If not, it should be fine short term, but long term, I'd get a separate amp for it. If you are driving it to clipping, it is only a matter of time before something fries.
