bigbassdave
Hey guys I've seen a lot of talk about the Behringer A500 on here and I read the specs. 2 x 230 Watts into 4 Ohms or 500 Watts into 8 Ohms bridged. At the risk of sounding like a total newb here I'm not sure what that means. Does it mean you can take the two channel amp and run it to only one channel producing 500 watts at 8 ohms? If that is the case does that mean that you could run (without bridging) 250 watts x 2 into 8 ohms? My two front speakers are rated up to 250 watts and are 8 ohm units so if I could get a two channel amp around $180 that would run them to their max potential I would be dancing in the streets. Thanks
