Dear All, Please Advice Matching 5.1 Speakers For Yamaha RX-A1050.
everettT Audioholic Spartan Feb 1, 2017 #2 There isn't really matching speakers for avrs. You want to choose speakers first, then choose an avr that can power the speakers to the levels you need without distortion or clipping. What's your budget, room size, listening habits, your location?
Y yepimonfire Audioholic Samurai Feb 1, 2017 #3 everettT said: There isn't really matching speakers for avrs. You want to choose speakers first, then choose an avr that can power the speakers to the levels you need without distortion or clipping. What's your budget, room size, listening habits, your location? Click to expand... The one exception might be sensitivity. If you're using a lower powered avr in a medium to large room, you might want to avoid insensitive speakers like tiny bookshelves or satellites, all things being equal. Sent from my SM-G360T1 using Tapatalk
everettT Audioholic Spartan Feb 2, 2017 #4 yepimonfire said: The one exception might be sensitivity. If you're using a lower powered avr in a medium to large room, you might want to avoid insensitive speakers like tiny bookshelves or satellites, all things being equal. Sent from my SM-G360T1 using Tapatalk Click to expand... For me personally, I'd buy the speakers I like and if they require more power to to drive them I'd deal with the requirements. For me fortunately, I have and would have more than enough amplification to power any speaker. When buyers have a limited budget, my advice is the same, choose speakers first then power
Y yepimonfire Audioholic Samurai Feb 2, 2017 #5 everettT said: For me personally, I'd buy the speakers I like and if they require more power to to drive them I'd deal with the requirements. For me fortunately, I have and would have more than enough amplification to power any speaker. When buyers have a limited budget, my advice is the same, choose speakers first then power Click to expand... I agree, I just know someone somewhere has purchased a cheap receiver and some cheap, tiny 83dB 1w1m speakers, which will most definitely send that puny amplifier into clipping at a 95dB peak sitting 10' away. Sent from my SM-G360T1 using Tapatalk
3db Audioholic Slumlord Feb 2, 2017 #6 everettT said: For me personally, I'd buy the speakers I like and if they require more power to to drive them I'd deal with the requirements. For me fortunately, I have and would have more than enough amplification to power any speaker. When buyers have a limited budget, my advice is the same, choose speakers first then power Click to expand... With a limited budget, I would reverse the options and choose speakers that a budget AVR can drive. My logic behind the reversal is a limited power AVR could clip when pushed too hard and damage the speakers. If budgets aren't all that limited, then I too would pick the speakers first. To the OP, the top 3 models in the RX-A series (your's included) have stout power supplies and hardy amplifiers. You have a wide range of speakers to choose from. I'm very partial to PSB and Yamaha as you can see in both my signature and galleries.
everettT Audioholic Spartan Feb 2, 2017 #7 3db said: With a limited budget, I would reverse the options and choose speakers that a budget AVR can drive. My logic behind the reversal is a limited power AVR could clip when pushed too hard and damage the speakers. If budgets aren't all that limited, then I too would pick the speakers first. To the OP, the top 3 models in the RX-A series (your's included) have stout power supplies and hardy amplifiers. You have a wide range of speakers to choose from. I'm very partial to PSB and Yamaha as you can see in both my signature and galleries. Click to expand... Sure I get it, however knowing what I know now being older I couldn't go that route. Again I certainly get it from building a system that way.
Y yepimonfire Audioholic Samurai Feb 5, 2017 #8 everettT said: Sure I get it, however knowing what I know now being older I couldn't go that route. Again I certainly get it from building a system that way. Click to expand... Klipsch offers some lower cost speakers for about $250 a pair that sound pretty good. I used to use a pair of 94dB klipsch icons i got for $120 on black Friday with a lousy htib receiver and had no difficulty achieving a clean output of 105dB. An entire 5.1 setup could be built on $1000 budget with something like that using a low cost 50wpc receiver and a Dayton sub from parts express, and it would have no problems achieving reference level SPL. Sent from my SM-G360T1 using Tapatalk
B Bino Audiophyte Feb 13, 2017 #9 What about you opinion about Jamo S626HCS ? Attachments S626HCS_CUT_SH.pdf 227.8 KB Views: 252
