Playstation 3 No Sound Through Hdmi Connection
Semper Fidelis
Semper Fidelis
I have this setup :
LCD - Toshiba Regza 32" WL66ZSG1080i
RECEIVER - Onkyo TX-SR505E
SOURCES - Toshiba SD-370E , Playstation 3
SPEAKERS - Center MAGNAT Monitor C210
Surround MAGNAT Monitor 110
Standfloor MAGNAT Monitor 990
SUB - MAGNAT Betasub 30 A
APC - SurgeArrest® Performance
WIRES/INTERCONNECTS - Belkin,Bandridge
and 2 problems:
-when i try to play dts music from cd-dts i get only white noise
-and 2nd and the most important i get no sound through HDMI only via tosslink wich has a lower bandwidth and it is also an unprotected link, restricting output of high bandwidth and protected audio (no 88.2kHz and 176kHz options too)
My receiver is a tx-sr505E Onkyo (if you missed that) ;)
Please help me out,i really want to get all the best of them.
Seth=L
Seth=L
Well first of all, that receiver does not process audio from HDMI.
When you play DTS are you using analog connections or optical? If the DVD/Blu-ray settings are set to output DTS both analog and optical connections will carry DTS (as well HDMI).
G
gus6464
I have this setup :
and 2 problems:
You have to upgrade to the 605 to get MPCM over hdmi. Or if you are looking for something cheaper that can do it you can go for the Sony STR-DG810.
http://www.onecall.com/ProductDetails.aspx?id=87319
GlocksRock
GlocksRock
the HDMI in that receiver is only a switch, not a repeater... you will have to go up to at least the next model to be able to get audio via hdmi.
Semper Fidelis
Semper Fidelis
Appreciate
Thank ya'll ...
I got it now ...
I have to stick to my optical for now ... i just bought the receiver so i guess that's it.
Otherwise i'm very pleased about the performance of it.
Appreciate ;)
G
gus6464
Thank ya'll ...
I got it now ...
Appreciate ;)
Since you just bought it can't you return it? Did you get a CC? I think they have extended return policy right now if you bought after Nov 1st.
Semper Fidelis
Semper Fidelis
Unfortunately in Romania i can not...
There is no such thing like return or refund policy,you bought it ... it's yours ...:mad:
Maybe you can be the seed of a new consumer revolution there:D Force them to change, bring them into the 21st century:D
ps, try not to use bold in normal writing unless you want to emphasize.;)
Semper Fidelis
Semper Fidelis
I'm fighting with the windmills here (Don Quijote like)
I'm moderating bodybuilding forums and it's a bad habbit i got from there ;)
P.S. Sorry about that...won't happen...thanks for your advise;)
