Playing MP3 player with loudspeakers and a receiver
N
narecupio
Hi,
I wasn't satisfied with my computer speakers, so I went searching for bigger ones - loudspeakers / bookshelf speakers.
I found out that those speakers do require a receiver. However, I have always thought playing through a receiver is for home theather system, TV, game console, etc., not a small MP3 player.
So, my question is, if I do get a receiver and two loudspeakers for my living room (an apartment, I don't think having louder sound is allowed here) and play it with my MP3 player, would I be getting lower quality of sound than playing it with different source other than MP3 player like Stereo system, computer, etc.?
Thank you for your help.
markw
Several issues here.
Yes, you need some sort of an amplifier to drive speakers. A receiver is the best bang for the buck.
These come in plain vanilla two-channel stereo as qell as the full-blown HT scenario. For MP3's, all you really need is two channels. Decent Two-channel stereo receivers NIB start at < $100 (best buy's Insignia brand, some Sherwoods and maybe others).
Likewise, you might find a bargain at a garage sale o or some other means. With these, all you need is a cable from a dollar store to connect an MP3 player.
As for sound quality, well, it'll be light years better with a receiver and speakers than it is through your headphones or computer speakers. Will YOUR* MP3 be the end-all and be-all for sound? Maybe, maybe not, but at least you'll now be set for other sources, the receiver's radio, a CD player, your computer, perhaps a turntable, and who knows what else.
* Depending on the compression rate you used to jam the music onto your MP3, you can get some pretty decent sound from it. The lower the bit-rate the "less pleasing" your sound is likely to be. I use WMA on a Sandisk Sansa and it rivals a CD player.
juliusdeane
My sound card has an optical out, and I use it to play compressed music through my 2.0 system. Not the greatest sound, but it's better than I thought it would be.
I know a lot of receivers have iPod input/control add-ons.
