Playing FLAC via my TV's audio path
N
Notaguru
My Sharp Aquos LC-60C6400U has been a cost-effective solution, with a good image and nice flexibility. It reads MP3 files from a USB stick, so one remote does video and audio very well - including program selection. A USB stick with ~40GB of MP3 music is read by the TV, and files are displayed for selection.
Audio from video and anything plugged into the set goes to a well-calibrated Yamaha YSP4000* sound bar and a Velodyne servo woofer. Most
LIVE audio from most LIVE television programs sounds amazing, evidence that the speaker system is doing its job.
HOWEVER:
Recorded MP3s don't sound so hot - a bit of fuzz accompanies certain transients, and despite my advanced age IT IS AUDIBLE. I see that this issue has been beaten to death, and is usually resolved by switching to .FLAC. I cannot figure out how to get .FLAC files through this system unless I buy a separate player, and then music selection/control would require YARC (yet another remote control).
The television set has unused HDMI inputs, and I have a fairly competent HDMI-connected DVD/CD player that works with the existing remote, but menus are not available so this is inconvenient.
The best solution by far (maybe the only one?) is to convince the Sharp TV to decode FLAC. Has anyone every accomplished this?
Thanks, gurus
*FYI: Yamaha's YSP technology uses multiple small drivers (40 - forty! - in this YSP4000), each separately amplified and with each signal independently generated by a clever DSP engine to permit manipulation of phase as perceived by the listener. To me the result is excellent, and my speaker judgment is based upon an audiophile history that includes Quads, LS3-5a, and a first generation pair of Hill Plasmatronics (from almost 40 years ago).
Lulimet
Lulimet
I'd be surprised if there is a TV out there that can decode FLAC. Your best bet is to get a media player like the WD TV.
djreef
djreef
or, buy a cheap Blu-Ray player with a USB input in the front like the OPPO BDP-103.
BoredSysAdmin
BoredSysAdmin
Amazon firetv stick costs under $40. With Plex or Kodi you should have no problems playing flacs.
WaynePflughaupt
WaynePflughaupt
While it’s true that MP3s aren’t audiophile quality, I can’t say I’ve ever heard the “fuzz with transients” problem that you are, and I listen to them often both on my computer with Swans speakers, and from my phone w- a good pair of Sennheiser headphones. I’m going to hazard a guess that the issue is with the TV’s electronics, probably a substandard D/A converter. The suggestion for a blu-ray player with a USB input is probably your best solution. Anything from a name-brand manufacturer in the $150-200 range should do the trick.
P.S. Welcome to the Forum!
Regards,
Wayne A. Pflughaupt
djreef
djreef
$500 is not cheap for a bluray player. The WD TV is $100.
I guess it's all relative. I know there are others out there that are cheaper (a lot cheaper). I haven't been out shopping players lately since I purchased my OPPO last year. I was just using this as an example.
DJ
