Play DVD audio in HTPC
jmhc
Greetings:
I need some help with DVD-Audio Playback. I have installed in my HTPC Asus Xonar HDAV 1.3 Slim soundcard, and Foobar 1.3 with the DVD-Audio plugin as default music player. The soundcard is hooked to my Onkyo TX-SR805 with the HDMI port, do I need something else to play DVD-Audio at full resolution (192/96 khz, 24bit)?? or this configuration is enough??
Thank you.
BoredSysAdmin
BoredSysAdmin
http://www.head-fi.org/forum/thread/432831/foobar-can-now-play-dvd-audio
dvda plugin for foobar
Great little plugin works excellently, just listening to Steely Dan Everything Must Go dvda using latest Foobar and Waspi output at 24bit 192khz on my Samsung R700 laptop MLP approx 5000kbps (as opposed to cd at 1440kbps), sound is excellent (drive alittle noisy though), when using the plugin particularly if using 24/192 make sure in the Playbak Devices that you have selected the correct output resloution eg 24/192 otherwise it may not playback, give it a try if you have any dvdas, any chance for a plugin for SACD (probably not as Sony are very tight about the codeing)
