Plasma Installation Help...
baaav
I have recently bought a Panasonic 42" Plasma and am looking to hang it but I am not sure:
(a) what is behind the sheet rock (I was told that it is concrete - by the building maintenance guy)
(b) whether there are any pipes etc within the wall
So I needed help in order to mount it and feed wiring through to the various components I have.
Can anyone help or provide some contact information for a contractor/specialist...?
(I live in the New York area)
:confused:
RLA
RLA
Hi
Get a Pro to install it for you I just came from a clients home that tryed to do a DIY install on a 50" Plasma and it was a disaster now its going to cost him 3x more for the install and drywall repair
look here for help
http://www.cedia.net/
and www.thx.com
Cheers
baaav
Thanks...!
Have contacted a number of companies from the cedia website. Fingers crossed...
specs_3
CEDIA member / National Installer
There is a national installation firm called DotTV2. I know they do installations for Sony and other high-end electronics companies and they are a cedia member.
Only thing is I think they may only service cities in Canada. Not sure, but they have a website: http://www.dottv2.tv
