Plasma - Hitachi PD7200 questions
JBong
Hi.
Just bought myself an Hitachi PD7200 plasma. Got it to work fine but still have a couple of questions:
1) I've got my cable TV descrambler connected to AV1. Don't know why, but when I'm navigating through the coded channels it shows up two channels in the same position. For example, I've got the paid sports channel on channel 35. If I'm on channel 34 and I press the up channel once I get channel 35 (which is set as "descramble on" on the setup menu), if I press it a second time I've got the same channel except now with the AV-1 composite indication on uppper right corner of the screen. How do I prevent the duplication?
2) Is it possible to add a tuner to it? PIP only works with 2 different signals...
3) Anyone can recommend some optimal picture setings for this display? Still using the default ones...
Thanks.
