You guys are forgetting one other factor: The extra energy used generates heat. In the winter, you are just paying for electric heat, not evenly distributed in your home. But if it is the summer, then, if you are using air conditioning, your air conditioner will also need to work harder to maintain the same temperature. You need to factor that into the cost as well, though that is not going to be easy to calculate.
Also, if one TV costs $180 per year to run, and another costs $90 per year to run (the exact costs, of course, being dependent upon the particular TV, and how it is used), that extra $90 could be put to better use. I have been buying SACD hybrid discs for $5.99 delivered:
http://www.yourmusic.com/
So we are talking about 15 extra discs for no extra money. Of course, if you are rich, this will not matter.
