I have a Panasonsic 42" EDTV attached to a Denon 5900 via DVI. I was expecting the images to be, well, perfect--crystal clear. They aren't. Sometimes I notice fuzziness in large background images like walls or sky. And in some dark scenes I sometimes notice short, flickering, colored, horizontal lines in big dark areas. The problems are more noticible with DVDs from TV shows (HBO--eg The Sopranos).
The other thing that bothers me is that the image using component connections doesn't seem to be significantly different than using DVI, which goes against everything I understand.
I calibrated the Plasma using DVE.
I'm using 480p out of the 5900.
I'm using high quality DVI cable. The length is 3 meters.
Am I just seeing the limits of plasma screens? Are there some other adjustments that I have failed to make?
Any suggestions/thoughts?
Thanks.
