Ok so basically what I am hearing is that...
- I don't need an amp with DSP
- I should shy away from inuke and get a used crown from my co-worker
- Using a calibrated mic with REW to dictate EQ settings and execute those settings via on a mini-dsp is the way to go.
- I also gather that the reason the Mini DSP is better than the AVR PEQ is because A) I can control up to 4 subs independently - and B) I can control 10 EQ points for each. (Whereas on the Yammy PEQ I can only control 1 sub channel with 4 EQ points.)
Does that about sum it up? If so - it all makes sense to me.
MUCH THANKS!
As for LFE on the Yammy - here is how it works. There is ONLY 1 crossover for the LFE according to Yamaha customer service. The way they explained it to me - the crossover frequency set for the front speakers
dictates the crossover for the LFE. There is no separate control. Thus if I have my fronts set to "small" and I choose 80Hz for the crossover - then my LFE is seeing everything below 80Hz.
However - that doesn't explain 1 thing. I have the ability to have the LFE channel active even with the Fronts set to "Large"...i.e. there is no crossover for the fronts (they see full). Thus begs the question - WTF is the LFE crossover Freq. in that instance?
I do not have Fronts set as Large BTW.
