Pioneer1014 making Buzzing Noise.*Help*
MasterChief
MasterChief
I recently turned on my reciever to watch a movie and i started to hear a humming noise from inside the AMP*** not from the speakers. First I thought it was my TV. So I turned it off, still humming. Then I figured its the subwoofer, I turned off the sub woofer Nada. Then I put my ear to the reciever and it makes a humming noise. Is it dieing ?? Im pretty sure it never made the noise before. I checked my other older recievers and none of them hum ? any clues any one else?
Rob Babcock
Rob Babcock
Moderator
Does your cable TV run into it? If so, unplug your cable and see if the buzz is still there.
MasterChief
MasterChief
um well the only thing is from my digi cable box, the a/v cables go into the reciever.is that what you mean ?
