Pioneer A/V receiver
rgriffin25,
For the subwoofer, I switched from On to Plus to Off (of course that wouldn't work if I have it set to "Off"
). No difference between any settings.
For the other speakers, I went to click on the advanced button, but hit the other one next to it (Stereo/Direct). Now I have all the speakers running. I don't know why what I did fixed the "problem"; I was doing that before, but for some reason it worked this time. It shows the "Dolby ProLogic" setting on the receiver. Now I just need to adjust the distancing of each speaker because the volume is way too low in the rear and surround speakers.
For the optical cable, I did have one, but with the above adjustments, it's working now. I don't know why, but I guess it has to do with just talking to somebody that knows what's going on
Now I need to figure out the subwoofer setting.
Also, I need clarification on something. If I have composite video on the DVD player and receiver, but not on the television, should it work to hook up composite video from the DVD player to the Receiver but then use a different cabling to the television (older model which only has WRY or Coaxial cable connection)?
