Pioneer VSX-D512 how to reset / problem diagnostic
jfh0000
Hi!
I bought a Pioneer VSX-D512, and now have several problems with it.
When i turn it on, sometimes there is no sound, in that case, the second "click" of the relais isn't there, in the other case there is only sound on the right channel.
The volume is splitted in only 2 stages! Sometimes the first til -35db, the second (louder) begins at -34db. If i use the remote control its the same.
When turning "ATT" on, it gets a bit louder.
When turning midnight on, i hear a high pitched whistle on the left channel.
Next problem, the signal of the sound source is on every input device, whether i choice another input channel.
I hope someone knows what parts could be the reason.
A support shop told me, a reset could help... Is there a way to reset the device on my own?
Thanks for the help!
