G
gotrocks63
i can not get any output from the surround sound outputs on the back. is there a fuse that could have blown ?
cpp
cpp
A few things
Has it always worked ?
Is there no sound when a CD or tuner is used ?
is the mute feature activated on your remote ?
bikdav
Perhaps try This
Try going through the menu thoroughly and make sure that you have all channels switched on that you want on. On the Pioneer, it is mostly a manual operation. I had the 812 and the speaker set up that I needed in the menu showed something like fl-fc-fr-rs-ls-sw or something weird like that. There are many configurations that it offers and you have to choose the right one according to how your speaker set up is.
