Pioneer VSX 1015TX Rear Channel Problems
N
NotherNewbie
Long awaited (2 weeks SEEMS long) Pioneer arrived.. ripped out the old setup and rearranged everything to accomodate the new.
connections went well.. easy to assign via menu.. and set the Mic out and kicked in the auto setup.. rear surround ERROR.. hmm.. redid and switched all the wires aroung.. still ERROR..
went into Manual setup and found the left tones coming from the left rear speaker.. however, the right tones come out of BOTH the left and right rear speakers..
anyone else have this problem?
)J&R couldn't have been nicer about the exchange.. called cust service, they emailed the prepaid shipping label and said send it back)
jaxvon
jaxvon
Sounds like a defective unit. I would send it back to avoid the headache. Mine has been working fine, and I've never had a problem like that. If you've verified that you do indeed have all your cable connections right, then iot's definitely the receiver.
Spiffyfast
Spiffyfast
yeah news to me, hadn't had a problem with mine yet, knock on wood
N
NotherNewbie
Thanks
Thanks guys.. was afraid it might be a wide spread problem, making me contemplate changing brands, although I really like the Pio..
I'll try one more.
