Pioneer Ventilation
saikou
I have a pioneer vsx 517 runing 5 jensen avx speakers. im getting a new cabinet soon and was worried about the ventilation. it gets pretty hot now and its just on a table. theres a fan inside the unitbut it never turns on. are the stock fans in theese recievers turned on at a certain temp or is mine just broken
Adam
Adam
saikou, welcome to the forum!
I've owned two receivers with built-in fans, and neither of them has had the fan turn on (at least that I ever noticed) even though I would consider them warm. I can't speak definitively for your model, but I'm confident that the fan is set to turn on at a certain temperature. Don't worry that the fan doesn't turn on as soon as you turn the unit on.
Adam
Johnd
Right on Adam.
And to augment, some receivers simply run hot for a number of reasons. The amps could run hot naturally, the heat sink could be undersized, you could be running a heavy load on it, you could be running it a warm envionment, you could be running it where there is no air flow, etc. If the receiver has not yet overheated, you seem to be adrressing a problem that has yet to occur. :)
Haoleb
Haoleb
Most recievers with built in fans do turn on at a specified temperature like you had guessed. It will probably be OK in the cabinet as long as there is a way for the hot exhaust air to escape once the fan does kick on. Most of the receivers Ive seen with fans have a tube type heat sink and they dont seem to be really effective until the fan comes on since the fins are on the inside and cant cool with convection like a more traditional heatsink.
emorphien
emorphien
My receiver doesn't have a fan, but in any confined space like a cabinet I'd monitor temperatures and make sure it ventilates well. Otherwise you might want to consider installing fans in the cabinet.
