Hi,
I just got the SC-05. I have a few questions I could not find online.
1. DRC (dynamic range compression). what does this do?
how is it different from midnight mode. when it's ON or OFF, what
difference should be heard? I could not seem to get midnight mode
so I guess I'm not in the right mode. the manual could have more
details, that would help.
2. I have a samsung lcd tv. I tried the preset codes built in the remote.
none of them seem to work. is there some other way than have to
teach it. I would assume the presets should work with the newer model
tv's. I have the 750 series.
3. Does anyone use THX cinema mode? are there certains modes that
sound better than others or one has to experiment? I watch standard
dvd's as well as HD and BD HD-Audio.
4. when I turn off my samsung BD player, it turns off the receiver.
is there away to disable that feature?
thanks for your help!
