Thanks for the great forum. I just purchased a Pioneer VSX72. I have not configured the MCACC yet however, I believe I am having an issue with the unit.
I have a Klipsch SUB, Polk bookshelf speakers (4), Klipsch center connected to the unit. I also have a Satellite receiver, DVDR and Comcast 6412 connected to the unit via Component connections.
When listening to the satellite or DVD or Cable box, I hear something that sounds like a relay/click (same sound that is heard when you turn the unit on or off) and the sound changes. The bass seems to drop considerably when this click occurs. This happens at low volumes. Also, when the unit is turned on, I occasionally get a great sound. Other times, the unit's bass is low (without changing/touching anything).
Is this unit defective or do I need to spend 1-2 hours doing calibrations...?
