problem solved
Thanks, problem solved. Pioneer does some dumb things. Don't get me wrong, I've been a fan since 1974 but sometimes they make me shake my head. For example if you set the front speakers to large LFE is not output unless the subwoofer is set to PLUS while the default setting is YES.
