Pioneer Elite VSX-74TXVi AV 7.1 Reciever Hdmi Switching/transcoding Thx Select 2
Z
zoran
New, with full warranty $1099 plus shipping.
VSX-74TXVi
THX Select 2 A/V Receiver featuring HDMI, i.Link, and Advanced MCACC with New Phase Control Technology
M.S.R.P. $1,700.00
(3453 KB, 494 sec @56k)
The goal is simple; create the multi-channel audio experience that the studio engineer intended for you to hear in your home. The VSX-74TXVi was designed to do just that and more. Building on a long history of innovations in amplifier designs the VSX-74TXVi's new Direct Energy Bipolar 7-Channel powerplant delivers 140 Watts to all 7 channels with absolute detail, power, and efficiency. To harnass all of that raw power, we've gone to a whole new level of digital signal processing with a new and improved Advanced MCACC calibration system, Burr Brown 192kHZ / 24-Bit digital to analog converters, new Phase Control bass management, and new Standing Wave compensation digital technologies. With so many new digital A/V devices available today, the VSX-74TXVi was built for connectivity. That's why we equipped this receiver with HDMI* digital inputs and monitor output. Now, a one-wire connection can send hi-definition video and multi-channel audio from HDMI equipped cable boxes, satellite receivers, DVD players, and even next generation game consoles to your new HDTV digital television. The VSX-74TXVi is also equipped with i.Link (advanced digital audio interface)for the absolute best in multi-channel audio transfer. Everything stays digital and you'll have far fewer wires to complicate things. Want some more connectivity? How about XM Radio "Connect and Play" and "Ready for iPod" connections. Both of these highly popular digital audio formats are now in the home and easily controlled from the VSX-74TXVi's remote control with complete On-Screen Display. We've noticed more and more custom applications happening out there so don't worry, the VSX-74TXVi is more than capable with complete discrete RS232c and IR command codes easily downloaded from our Custom Installation Support area of this very website!
* HDMI connection may not allow transmission of copyright material depending on the capability of the signal source. Click here for alternative connection options.
* For on-screen display through HDMI, use a monitor compatible with an HDMI / DVI input resolution of 480i or 576i
Power
Power Amplifier Design New Direct Energy Bipolar
Surround Power 140 W x 7 (20HZ - 20kHZ @ 8 ohm, 0.09% THD)
Stereo Power 140 W x 2 (20HZ - 20kHZ @ 8 ohm, 0.09% THD)
Digital Decoding & Processing
Digital Engine Sharc-EX + 48 Bit Motorola
Dolby Digital 5.1 Yes
Dolby Digital EX Yes
DTS 5.1 Yes
DTS-ES Discrete 6.1 Yes
DTS 96/24 Yes
DTS NEO 6 Yes
Pro-Logic II DPL IIx
Windows Media Audio 9 - Professional Yes
THX Yes (Select 2)
Air Studios Tuning Yes
Surround EX Yes
Pioneer Original Surround Modes Advanced Surround 6 Movie / 7 Music
Virtual Surround Back Yes
Midnight Listening Yes
Loudness Yes
MCACC Yes
Speaker Configuration Yes
Speaker Size Yes
Speaker Level Yes
Speaker Distance Yes
Acoustic Equalization 9 - Band
Advanced MCACC New
Phase Control Yes
Standing Wave Control Yes
Room Acoustic Status 3-D Display via PC Yes (Pre & Post Calibration)
Analog to Digital Conversion 96 kHz / 24-Bit
Digital Analog Conversion (DAC) Burr Brown DSD1791DBR - 192 kHz / 24-Bit
Connectivity
i-Link Yes w/DSD Direct
Ready for iPod Yes
XM Ready Yes
USB PC Input Yes
Analog Audio Inputs 10
Analog Audio Outputs 3
Digital Inputs 7
Optical In 5 (Includes 1 Front Input)
Coaxial In 2
Optical Digital Output 1
Multi-Channel Input 8 Channel
Audio Pre-Output 8 Channel
Composite Video Input 7
Composite Video Output 3
S-Video Input 5
S-Video Output 3
Component Video Input 3
Component Video Output 1
Video Conversion Yes - To HDMI
Video Adjustments Yes
Video Signal Select Yes
Component Video Frequency Response 100 MHz
HDMI Inputs 2 (HDMI connection may not allow transmission of copyright protected material depending on the capability of the signal source)
HDMI Output 1
Headphone Output Yes
Multi-Room and Source Output 3 Zone - Main, 1 A/V, 1 Digital Audio
12 Volt Trigger Yes x 2
Front A/V Inputs Yes
IR IN/Out Yes
RS-232C Yes
AC Outlet Yes
System Remote Control Port Yes SR+
SP Terminal Type Banana
Speaker A/B A/B, A+B
Adjustable Speaker Configuration Yes (2nd Zone /SB Channel / MR&MS
Convenience
On-Screen Display Yes (HDMI OSD 480i only)
Dot Matrix Display Yes
Remote Type LCD
Pre-programmed Yes
Learning Yes
Macro Commands Yes
Construction
Front Panel Aluminum
Transformer Stabilizer Yes
Direct Construction Yes
Warranty
Terms 2 years parts and labor
Dimensions
Width x Height x Depth 16 9/16 x 7 3/8 x 18 3/16
Weight 35.3 lbs
mitch_88
shipping?
how much to ship this to 95403? You said this has the factory warranty. Pioneer will only warranty their products if purchased from an authorized dealer. Are you a dealer?
