Pioneer Elite DVD player help!!
N
no1maestro
We had a power outage in the area a few days ago. No lightning strikes, no brownout just outage. When the power came back on everything was OK with the exception of the DV-47Ai Pioneer dvd player. It will not turn on, either on or to standby mode. Is there some trick to resetting this. We don't think there was any damage since all other components are fine. I would appreciate any help. Thanks!
adk highlander
adk highlander
Sith Lord
Try unplugging it and leaving it unplugged for about a minute and then plug it back in to see if it will reset. I don't know the technical reason why some electronics freeze like this after an outage but leaving it unplugged should "clear" it and allow it to reset.
