Pioneer Elite 56 THD at 6 ohm
mudakas
Hi, it's me again :)
So after playing around with my new toy I decided that I need bigger speakers :) :D
Ok seriously I decided to build DIY 3-way hi-end speakers using a kit. But those come with impedance of 6 ohm, and "bastards" from Pioneer didn’t mention anything in the owners manual about THD at 6 Ohms despite the receiver can be switched to 6 ohm load and is also thx certified... so am dialing pioneer customer support - after passing three levels of "customer support" I got personal number of some kind of chief designer of their Elite line. He says hold on - 10min...... at 6 ohms it is .08%THD. Really?-yes. But Manual says at 8 ohms THD is 0.09%.:cool: :confused:
Who cares it sounds awesome, but anyways?
V
Half Fast
OUTRAGEOUS! The only thing you can do now is unload that thing cheap! Don't bother with ebay, PM me for my address. I'll help you out just this once. :D
