No offense taken, I can assure you I have made that simple mistake in the past. When I connect to AV1 there is no picture, image, etc. Hitting setup, as recommended for first time setup, nets nothing on the screen. I switched to S-video on AV1 and have dvd setup functionality. When I insert a disk, and I have tried several, there is no playback. It will show the respective tray/disc number on the bottom right of the screen, and loading on the top left. However, after a short period of time the unit stops loading and fails to play, regardless of disc location within the tray. Same thing applies for audio cds in cd mode.
I recently opened the case to repair the unit insomuch as the tray would not remain open. I discovered a disc that had been dumped from the tray laying unceremoniously against the right side of the chassis; quite damaged, bent and cracked from the assault by the tray's opening/closing action. I also re-lubed the tray rails, checked for ribbon securement on all boards, and cleaned the lens. I am wondering now if my disc read error is not an alignment issue. If it is, how do I go about realigning the tray and/or lens carrier?
On another note, regarding AV4 and progressive scan players, 480p and 1080I. When I connected my Cyberhome DVD player to AV4 via the Y/Pr/Pb cables I had the same sort of distorted horizontal lines. Is there a particular setting I need to have engaged from the player to make the image display correctly, or should it default to that setting on its own? Also, when I connect the same to AV1 the color balance is on the extreme side of red. I tried to adjust the color via the tv, but to no avail. Is the balance setting needing to be done via the dvd player itself? I know with the pioneer it gives instructions in the manual. My cyberhome player (aquired at the same time) does not have a manual with it. I am trying to remedy that presently. I am thinking the cables may be bad in any case or I have a short in the set.
Thanks for any help you or anyone else may be able to offer. I consider myself fairly knowlegable regarding electronics, but even I get tripped up from time to time. I am more concerned right now with keeping costs low on repairs/replacment, hence the inquiry. I don't want to spend what I need not, and still repair what I can.
Again, thanks for the help, I am eternally grateful.
