Hi there,
The BDP-150 is a fantastic player at $300 (what I paid) let alone at $150. The only thing you'll have to do is download the firmware upgrade to enable the DTS master audio decoding which it supports internally but does not decode out of the box. The firmware needed for DTS MA, LFE crossover settings and additional speaker options is v1.32. Pioneer just released v1.37 this month I believe which is strictly a performance enhancement upgrade. After that it is a sweet sounding piece of gear. I use a Lexicon RV-5 and use the audio analog inputs on the bluray to get the new codecs. Sounds awesome. Go under bluray.com and download the firmware onto a CD-r as an image file. Then pop it into your player and presto! Create 2 discs, one for v1.32 and another for 1.37. Make sure you burn it as an image file or it won't work. I believe instructions are included there step by step. Below are the changes you'll get with the upgrades.
BDP-05FD Firmware Update (v1.37)
Information
Manufacturer
Type
Version
Release date
Downloads
Pioneer
Firmware
1.37
Sep 25, 2009
2607
Description
Pioneer Elite BDP-05FD Firmware Update.
Ver 1.37
- Enhances stability of BD-ROM/BD-R/BD-RE/DVD-Video playback
- Performance improvement
Changelog
Ver 1.32
CHANGE HISTORY:
- Enables the following new functions. Refer to the Operating Instructions addendum "Notice on the Addition of Functions" for details.
1. DTS-HD audio output
Converts DTS-HD audio to linear PCM for HDMI OUT (MAIN) terminal.
Converts DTS-HD audio to analog audio for the AUDIO OUT (7.1 ch) terminals.
2. Image file playback
Play image files recorded on DVD or CD.
3. LFE Crossover frequency and additional Speaker settings for AUDIO OUT (7.1 ch) terminals.
- Enhances stability of BD-Java playback (*)
- Fixes the resume playback function after switching off the player by pressing the STANDBY/ON button during playback of BD-ROM discs.
* The player's action can be slower than expected depending on contents (menu, game, etc.) included in certain BD-Java discs.
Good Luck.
