Pdp 4212
Good review Clint – I recently purchased the PDP4214 version of this unit.
My budget for a TV was around $2000/$2500. I got this unit for $2000 at Costco.
As you say, in your review, there are good and bad points to this set. The burn in issue does not seem as bad now that I have had the set for a couple of months. My main issue is with the weird effect in some of the dark scenes, I think this may be the posturization or banding you refer to. What I am wondering, is there a better set out there in my price range ?? I am reluctant to return the unit and buy something else that falls short, either in the same or other areas.
I hear that the entry level Panasonics are supposed to be good TV’s – but to be honest I think the new Panasonics look ugly, particularly when compared to the Pioneer. But if the Panasonic blows the Pioneer away then this may be a worthwhile sacrifice to make.
Also, do you think the use of an upscaling DVD player, with an HDMI cable, would help. Or would I not find it much different from a progressive scan DVD with component cables.
I know that compromises are going to have to be made when talking about entry level units, when compared to the higher priced sets. However, $2000/$2500 is still a lot of money to drop on a TV, so I am just trying to get the best value for money as possible.
R.D.
