Quant said:
Does that work with the parametric eq as well, while also allowing you to move the center freq band?
I'm not quite sure what your asking; the Denon/Audyssey eq will of course initially take measurements in up to 6 or 8 positions in your room (depends on what model receiver you get). From there, it will do it's calculations and give you a few eq settings to choose from if you like
1. Audyssey (aimed at room corrections)
2. Front (matching the other channels to the sound characteristics of the front channels)
3. Flat (obviously, flattening out the curve from each speaker)
4. Manual
You can adjust these eq settings if you like using 'Manual' to whatever you like and I think it does up to +/-20dB (in 0.5 dB steps) over 9 band (63, 125, 250, 500, 1k,2k,4k,8k,16k Hz). You can copy any of the eq curves from the aud, front, or flat if you like, and adjust those for each indivual channel, the default is adjusting both left and right channels together, but this can be changed and eq them indivually, and the center channels is eq'd separately, as well as the surrounds.
One last feature for the sake of completeness, you can also program when to use each eq curve, say you want no eq when listening to your CD source, but what Audssey while listening to your DVD source, or flat while listening to your LP player....
If that doesn't help, let me know.
Brad
