Picture setting/calibrating Samsung ks9800 78
L
Lakers8/24
Hey anyone,
I was wondering if anyone had some great pictures setting for the ks9800 78 or any ideas where to start on the calibrations?If anyone can help I would highly appreciate it that guys.
Other folks' settings won't necessarily work for your set. As mentioned, I'd start with a calibration disc to make sure you have the basics down. I'd turn off any "features" in processing you don't need, go to the most accurate mode (usually movie mode), turn off soap opera effect, etc...
If you really want to tweak you'd need a calibration kit and diy, or hire a professional calibrator (assuming your set has an extensive color management system to take advantage of such). Here's a site that sells gear and has tutorials and such for your own tweaking https://calman.spectracal.com/
L
Lakers8/24
Thanks for the help guys I will start out with the disc and go from there.
If you have a disc player and a disc with the THX Optimizer featurette you might start there (it has some basic audio/video setup capabilities). Otherwise the Disney WOW, DVE-Digital Video Essentials, Spears & Munsil discs are some you might look at.
