OK, so it turned out to be a book....
Well, fired it up real quick and dirty in my 2ch rig. Analog only from my CDP to the CD input, stereo, direct. Bass was slightly subdued, and the highs are a bit dialed back at the top - not quite a lack of detail, but for lack of a better term, less of a "round" sound compared to my 7200. Though a bit flat, midrange detail seems good, but when I went back to my 7200 (in class AB mode), it seemed pretty clear that there was not as much depth with the 1014. It sounds almost identical to the 41Tx I had listened to previously.
Power is what I was most curious about, and when I cranked it, this is where I really started to notice the difference. The 1014's power was all at the top. To get the 1014 at a moderate level, I was at -18 on the dial (MCACC off), and the volume only really seemed to make significant changes when I reached about -20, as if 90% of the the volume range was between -25 and 0, and I figure at -20 I'm at about 85% of total power. To achieve the same volume on my 7200 I'm at less than 30% on the dial. I checked the manual, and found it to be rated 20-20K .09THD, but it specifically states that is only with the two main channels driven. No numbers given for all channels driven, and while the numbers look good, with just my two bookshelf speakers hooked up, distortion was quite evident when I pushed it up to -12. With Loreena McKennit Live in Paris & Toronto, her vocals quickly became "fuzzy" and the loss of control was obvious during the heaviest vocal passages, so I brought it back down. Back to the 7200 - not a hint of this fuzzy sound at even higher volume. Perhaps there is some kind of current limiting going on in the amp section? I am now hesitant to even hook up my 4 Ohm mains to this guy... Of note - I have an Audiosource amp which puts out 80w x 2, and it has a db/watt meter. With it hooked up to these speakers, at 50% gain on that guy, my speakers registered peaks of just under 1w of useage for average volume levels in my room.
Build quality is very good for a receiver in this price range. The remote is impressive also. I'll be trying out the 1014's DACs tomorrow, and possibly MCACC. I'll also use a SPL meter so I am comparing sound at the same registered volume.
First impression: it's not going to be outgunning the 8300 any time soon
IMO, it's par for the price range, and is certainly not a bad receiver by any means. I picked it up for $300, BTW.
