Phono preamp - need some advice
sabernar
sabernar
I'm in the market for a phono preamp. I'm currently in the middle of a slow upgrade of my system (just got Monitor Audio RS6's & RS1's from my front and rear speakers) and I'm planning on upgrading my phono to a low-end audiophile level (Rega Planar 2? Music Hall MMF 2.1? I'm not sure yet...).
I was wondering what level phono preamp I should go for. Are any of these decent enough?
Pro-Ject The Phono Box MKII
Cambridge Audio Azur 540P
Music Hall MMF Phono Pack
I don't want to go crazy on this piece of hardware. Even though a tube preamp would wonderful, I have a budget (~$100) that I need to stick to.
Thoughts? Ideas?
Thanks for your help in advance.
emorphien
emorphien
I'd add the NAD PP-2 to that group as well. I couldn't tell you what the best choice among these is though. I bought the PP-2 because I desperately needed a preamp and it was available locally for a good price. It has turned out to be just fine for my needs and I'm still using it.
MUDSHARK
MUDSHARK
If you don't get much response here try Stereophile's boards. They have a number of vinyl people there that could likely give advice on the strengths and weaknesses of your stated options. I use the phono pre-amp in my Prasound pre-amp so I'm unable to offer an opinion.
c_h_shin
How about a used Parasound zPhono? As I recall, it was on one of the "Recommended Lists" recently.
