Mort's right.
If you plug a turntable into a standard line-level input, the results will be lousy. Phono signals are lower than standard line-level and are equalized differently. So a phono input boosts the input more than normal and also re-equalizes the signal.
You can buy external devices that will convert the signal to a standard line-level signal.
