robertkjr3d
Ok I have another question...
I thought this one would be a cinch, after getting it hooked up... but no it not work very well. Very poor sound.
Here's the deal: I have a little Radio Shack converter that plugs into a cellphone/house phone which converts 3.5mm conector to the standard headphone size. Then I have a conector that plugs into the standard and splits off into two rca female ends. 1 of course is the mic, and the other output audio. Well I taped off the end I don't need the mic in this case. So I split the other RCA Male to 2 male ends. Then I take these male ends and plug that into the amplifier.
This is what I get... Kinda of a spark sound everyonce in a while. I have to crank the amps volume real high, which causes distortion... and the sound still sucks.
What am I doing wrong?
What I'm doing is basically the long way to do this product... would this product do that much better? See this link... now I don't have rights on this site to actually put a link but put it together and you can go to the site.
www shoptronics com/sthe3pltodur.html
actually in looking at that product again... I would still have to tape off one end, and split the other one, because one end would still be the mic end.
