Philips HTS easy fit speaker compability with new unit
K
Kit Skie
My Philips HTS 3565d is no longer powering on. Is there another theatre system other than a Philips, such as a Samsung or LG, that is compatible with these easy fit speakers so a lot of rewiring doesn't have to be done. I would like to be able to just switch out the unit. Thanks!!
markw
What are "easy fit" speakers?
If there is one fat wire going from the control unit to the woofer and all speakers are routed from the subwoofer, then no. It's all part of one integrated system where the brains are separate from the brawn and neither one works without the other.
[edit] I found the manual. you can probably use the main five speakers it their impedance is high enough (I couldn't find that information) if you cut the plugs off but the woofer won't work. You will need a powered subwoofer.
Seth=L
Seth=L
The resolution is just low enough that I can't definitively tell, but it appears the front left and right are 6 ohms and the center is 3 ohms. The power cord is blocking the surrounds, but those are likely 6 ohms as well. OP could help us more with figuring this part out.
WaynePflughaupt
WaynePflughaupt
This is a typical problem with HTIB systems. Those plugs on the speaker cables are proprietary, not anything “off the shelf” that would allow the user to swap out with equipment from other manufacturers. It’s possible that some other manufacturers use the same plugs, but the likelihood of anyone here knowing which ones do is remote, as the enthusiasts here generally have little regard for these low-end pre-packaged systems. Problems like you’re experiencing are only one of the reasons.
You might be able to get a new HTIB system from a different brand and simply splice the plug ends it comes with onto your current speakers. That’s assuming the impedance if the old speakers is compatible with the amplifiers in the new system.
Which is another reason we don’t like these things. Basically they are self-contained systems that are not designed to have their parts “mixed and matched” with the products of other manufacturers, as you have with a standard-component home theater system. True, standard systems are much more complicated to set up and operate, which is possibly one reason why you went with a simple all-in-one system. But the trade-off for ease of set-up is strictly-limited flexibility.
Regards,
Wayne A. Pflughaupt
