Bravo! Your Audio is finally back on track.
Hi jamie; thxs for the message... after checking everthing again; I realized I did not check the trigger switch on the amp... I unplugged it; plugged it back in and presto... sound! Very strange though... cause through my trial/error the amp was on... but for some reason it was not powering my speakers. I have no idea as to why this happened! Hopefully all is well now
THANK YOU!
Hey buddy,
Seems it's always a stupid thing that we forgot to check. But in this case the trigger switch did trigger the problem!
On your DTC-9.8, do you have a delay for the trigger?
And is the trigger set for the appropriate device?
Lastly, make sure that the trigger cable is well connected all the way inside the jacks at both ends.
Glad you get your audio back. It was a TRIGGER thing that trigger the problem.
Cheers,
Bob
